Larry Dillon said: The light should blink in a sequence , and then start over again, most of the times, it is 3 through 10, then pauses and starts all over again.
I don't think there's a pause at all, it just blinks continuously....
Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective. Means you most likely have a video problem with the set and an experienced tech will need to troubleshoot this puppy, as there are too many things that this problem can be to explain them all to you I'm afraid. good Luck
Is there a code to the blinking of the light, and is there any sound?
Thanks for your reply! The TV does have sound, but the picture never "initializes", it never comes on. What do you mean a code?
