My Sony tv just decided it was going to cost me some money and blanked out on me, has always work good, but now when i turn it on i hear a click, standby light flashes, then another click then picture appears, works fine for 5 minutes then pictures goes blank and sound still works, i unplug it let it sit for a while and try again and sometimes it will work for 6 hours or so and other times it will blank out after 10 minutes, i have tryed changing cables, resetting tv, checked closed caption, everything i could think of, i am hoping someone has experienced this problem and can lead me in the right direction as to if it is worth fixing or possibly i can fix myself. thank you
How many times does the standby light flash?
Standby light flashes usually like 11 times before picture comes on, but after it goes blank it just flashes constantly, and there is no sequence or pauses in between flashes.
Continuous Blink Once A Second, No Pausing As Discussed Above---
No reply from the jungle IC301 (data bus is busy, shorted to ground or held high), IK video path is defective.
Try turning up the screen control slightly, clockwise, as your symptom is one that indicates a failing picture tube. Good Luck
