ps61670
5 posts / 0 new
cptnelectron
ps61670
thanks for quick responce to my delema i have checked witth global semi  rca rep for t chip  [la7612n] they simply cross it to la7612  nte cross shows nothing  i have la7612a  will it work   or do i need to order specific  la7612n    appreciate your input . cptnelectron.
You can use the LA7612, the
You can use the LA7612, the LA7612n, or the LA7612a for the same video IC in just about any set. Or the RCA part number is 241266.  If this set is indeed an RCA TV set, I found thiese other problems around the video IC bad.  Found C26903 pn#214729,a 22mfd@35vdc C26902 pn#220998, 1 mfd@100vdc capacitor physically damaged, located on the analog comb board, They are he coupling capacitors for the video input to the combfilter. Also coil L26901 pn# 244249 open and was also replaced.  Good Luck, and let us know how you made out with this repair.
cptnelectron
checked everything on your
checked everything on your list and more cr800 still shorting after set runs for a while  no change in video even after swapping out t-chip caps test ok  etc  i  unfortunately do not have schematic for this one am trying to aquire one video on the screen seems to be rolling vertucally as well maybe just cant tell with low lum thanks for your help cptnelectron.
Unfortunately, this is one
Unfortunately, this is one repair that you get a schematic, or cut your loses.
cptnelectron
Larry Dillon said:
Larry Dillon said: Unfortunately, this is one repair that you get a schematic, or cut your loses.
 schematic is on its way   your right   leroy   thanks again
