If a player or recorder will not read some audio disc, and not the DVDs, usually it is an indication of a dirty lens, or the optics are getting weak and will need to be replaced. You should first try to clean the lens. Then if that does not help, most likely you will need to replace the player, as the cost to repair this will far exceed the cost of a new one. Good Luck, and let us know how you make out with this player.
