Philips 55PP935217
4 posts / 0 new
JamieK
Philips 55PP935217
How do I replace the ICs own my projection TV
What IC"s are you talking
What IC"s are you talking about.  My looking glass ball is broken today.  What are the symptoms of your TV set.  Be a little more descriptive please and maybe we can assist you.
benchd
Im referring to having
Im referring to having convergence problems
You will need to get a
You will need to get a service manual first.  Locate the convergence IC's.  order the right numbers from MCM electronics.. Do not order the cheapest ones you can find, as you will be in the same boat a few months down the road.  You will need to know how to solder and unsolder on solid state printed circuit boards.  Then before you install the new IC's, you will need to put some heat sink compound on the backs of the IC's.  If you have no solid state repair experience, play it safe and call in a trained tech to assist you in this repair.  Good Luck, and please let us know what you did to get this TV set operational.
