Sony XBR TV will not turn on!!
5 posts / 0 new
qwick
Hi I am having the following problem with my Sony KV40XBR800 when I try to turn the TV on it does nothing but blink the stanby light 7 times.  I imagine this is some kind of error code but I cannot find what this error is.  Anyone out there that can help me with this issue?
Brent55
I have the same problem. Have
I have the same problem. Have you had any success in getting the issue resolved. Does anyone have an answer to this issue?
Silva
Silva Member Today at 4:59 PM
Silva Member Today at 4:59 PM There are two components that you should check in the power sup. are T8005,and Cap 6532.This is not a repair that can be done by a novice,. Good luck and tell us how you made out on this set.
ed05
Silva do you know the
Silva do you know the specifics of cap 6532 and T8005.  I found where I can buy them and I know I can do the fix myself, however, I cannot find the sony part number for the cap and if I knew this it would help out alot.
Chris
C6532 is a 39000PF at 800
C6532 is a 39000PF at 800 volts and the Sony part number is 1-137-741-22.  Good Luck
