Problems with Magnavox Mod MWR20V6
7 posts / 0 new
Thom
Thom's picture
My Magnavox DVD/VCR player/recorder has started displaying an error message as follows:
    Error Can not record on this disc.
     E4  54037380
It displays this message no matter what type of disc is in the machine.
Does anyone have any insight on this issue?
dans_repair_service
dans_repair_service's picture
Try cleaning the lens with a
Try cleaning the lens with a cotton swab and alcohol.  The first step in a recording is to determine the media type.  If this function fails, the error message you posted will appear.  This can fail for a number of reasons, but most likely either the lens is dirty or the optics are beginning to fail.  How old and how many discs have you recorded?
Dan
Thom
Thom's picture
dans_repair_service said: Try
dans_repair_service said: Try cleaning the lens with a cotton swab and alcohol.  The first step in a recording is to determine the media type.  If this function fails, the error message you posted will appear.  This can fail for a number of reasons, but most likely either the lens is dirty or the optics are beginning to fail.  How old and how many discs have you recorded? Dan
HI Dan and thanks for the reply.  My machine is less than 2 years old and I've recorded approximately 100 discs.  I clean it regularly with a Phillips DVD lens cleaner that I purchased at the same time I purchased the unit and I also remove the cover and keep the unit dust free.  I use mainly MAXELL DVD-R discs because I've had the best quality recordings with them.  I tried several others but they did not have the reproduction quality of the MAXELL discs.
I will try your advice and let you know how it works.  Thanks again
dusty3129
dusty3129's picture
Thanks Dan,
Thanks Dan,
That fixed 3 of my DVD recorders.
dusty3129
dusty3129's picture
Thanks Dan,
Thanks Dan,
renee629
renee629's picture
same thing here cleaning does
same thing here cleaning does not work
ROB26847
ROB26847's picture
I HAVE ONE THAT DISPLAYS SAME
I HAVE ONE THAT DISPLAYS SAME MESSAGE BUT PLAYS MOVIES PERFECLY. COULD IT STILL JUST NEED A CLEANING. I TRIED A LENS CLEANER BUT DIDNT WORK. I REALLY APPRECIATE ALL YOUR HELP. THANK YOU VERY MUCH.
