Technical Problem
Claire and Shaun
Technical Problem
Hi Everyone
I've got a JVC 56" tv which is just over a year old but am having problems which no one seems to know how to sort out.
The tv just turns itself off at random times and we don't know why.  Has anyone ever had this problem before or know what it could be?
You could have a power
You could have a power regulator problem and the set is shutting down to prevent damaging other components, or there could simply be a bad connection inside this TV set, on the printed circuit board assembly.  If the set seems to go to a bright scen, and the set shuts down, then there is most likely a fault in the beam current detection circuit or even still in the regulator curcuit I mentioned before.  These are really not the typical type of repairs someone should attempt without the proper documentaion, the proper tools, as well as the knowledge of how the differant shut down circuits work in this TV set.  Good Luck, and let us know if you get this set repaired and what was wrong with it.
