Locked remote
Aforce
Locked remote
In need of a 4 digit unlock code for a mitubishi VS-4003R TV.
You will need the original
You will need the original remote for the TV set. and follow these instructions, and you should be set.  Bypassing the V-Chip Lock on most Mitsubishi sets:
Mitsubishi sets use a four-digit passcode that is required to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus.
If you don't have the passcode, it is easy to bypass.  This is neccessary if you forgot the code, purchased the set used, or if you simply don't feel like searching through your files to find it.
To bypass the V-chip:  You can view the locked shows by pressing the number 9 and QV buttons on the remote at the same time, whenever your  passcode is requested.  This process  temporarily unlocks the TV.
To reset the code:  When you use the button combination 9 and QV while entering the V-Chip Lock menu,  this process deletes your old passcode  and prompts you to enter a new passcode.
Good Luck and let us know how this turned out for you.
