need service menu stats, tosh 42h82
5 posts / 0 new
Tim42
hi, i have a toshiba 42h82, i think my service menu options have been played with, i have a few strange issues. what im looking for is a list of someones sm settings so i can reset my unit to proper working order. any help would be very appreciated.
You think they have been
You think they have been messed with?  or you played with them?  The settings do not change by themselfs my friend, unless there is a compnent falure in the TV set itself.  You really need to get the service manual, as anytime you try to adjust a service menu, you should ALWAYS write down the settings that are on the TV set before you change anything.  A service manual is available HERE  Like I said before, the settings do not change by themselfs and the cure all is not to simply adjust the service menu.  What is the original complaint or problem that the TV set was having?  Also one persons settings will not be the correct settings for your set, as all TV sets have differant settings, as even TV's with the same model number will have differant part tolerances.  Good Luck, and let us know what happens or if you get this TV set repaired ands what it took to do so.
Tim42
well there are several issues
well there are several issues, the main issue is that i have no pic size options, it sipy says "not available" when i hit the button. the other issue is the clours and screen size is very much off. i realize each set is different but at least getting an idea of good working values might help. i have a funny feeling somone has either messed them up or has changed a module or bypassed somthing. i have a manual on the way wich will solve my questions im sure.
Ok I do understand what you
Ok I do understand what you are saying my friend, but is this a set you have owned for a while or one you just recieved?
Karel W
Go to http://tvservicemenu
Go to http://tvservicemenu.blogspot.com to get TV service menu every day via email
good luck.
