TV problem.
1 post / 0 new
Jmowie4
TV problem.
Alright guys let's see if anyone might be able to fix this.
I have a Samsung 30" HDTV and I've been having a problem with it lately. The TV/Video option which switches you from tv outputs like DVI, Air 3, AV1(2)(3), Component 1(2), etc... constantly switches between these different outputs by itself. It started out of nowhere really and is totally obnoxious. You can't watch anything because you get it on DVI so you can watch Satellite and then it switches on it's own to Air 3, and then slowly proceeds to cycle through the rest of the TV/Video selections. At first I thought it might have been that the TV/Video button on the side of the TV was stuck but it turned out false and there doesn't seem to be any damage to the side-button board and the wires going into the main part of the TV. Any farther than that I can't tell you because I'm not reaching in there and making things worse. If anyone knows anything that causes this or needs a little bit more detailed information please post.
Thanks, Jmow.
