Switch'd my Koss entertainment system over to the PALNTSC Image display, which as far as I'm understanding it, I gotta go to Germany to use my entertainment system!!! I can't access anything!! On top of that, stinkin' Koss isn't making anything anymore but headphones! I need help or it's hundreds of dollars thrown to the curb...HELP ME
Well, there's two TV systems mentioned in your post. PAL and NTSC. PAL is used in Europe and other countries around the world, NTSC is what is used in the United States and a few other nations. If you switched your system/player to PAL, but own an NTSC TV, you should be able to follow the same steps you did the first time to switch it back to NTSC from PAL.
