My 32V432T Television problem
paulanoon
i am having a problem with my television.  It is a 1 and 1/2 yrs old and today it shut off by itself.  Also the buttons are not working right.  You press the volume button and it takes it to the menu.  You press the on/off button it does nothing.  The picture, when I do see it is fine.  The remote doesn't work either.  Please help
First thing you do with a set
First thing you do with a set that acts this way is to unplug it for a period of time.  Like I would saqy a minimum of 3 to 6 hours.  If that does not corrct your problem.  Check all of the buttons on the TV set as well as trhe remote tramsmitter itself for stuck buttons or buttons that do not seel yjr same as all the other switchs. it shouls feel like a small detemt. on the tips of your finfer. Good Luck and let us know if this helps any?
