Hello, Can you help? I have audio but no picture on our Sony TV KV35V36. The red stand-by/timer light just keeps blinking when you turn it on. Do you have any suggestions on which parts are needed or it is ready for the trash? Thanks!
Copyright © 2020
Often these errors are related to a bad solder joint on the main-pcb or crt-board. You can check this by tapping on some parts on these pc's with an isolated screwdriver. Whenever you tap, and the picture goes dark, you're sure it's a bad solder joint and you'll need to re-solder it. Also bad solder connections around the flyback transformer as well as in the vertical sweep circuits. Please If you have no TV repair experience, call in a tech to assist you in this repair. Good Luck and let us know how you made out with this repair.
