Hitachi 53SWX01W Ch No. DP07 Shuts off on own
trinab
My Hitachi shuts itself off.  Sometimes in 5 hours sometimes 5 minutes.  I bought this TV from a small repair shop about a year ago (with an extended warranty) used.  The guy has since disappeared.  Big shock..  I am wondering if this is something that I could fix myself.  If so were I can get the info.
It could be as simple as a
It could be as simple as a bad connection in the horizontal sweep, sweep power supply, or the main power supply circuits.  If you or a friend knows how to solder and work on printed circuit boards it would be worth having a look into.  BUT there is alot of dangerous high voltage inside these puppies, so just be careful. If you do not have any circuit board experience, play it safe and call in a pro to assist you in this repair.  Good Luck, and keep us informed about the repair of this TV set.
