what happens is i plug it in, the red power light comes on, then when i press the on/off swoitch the green light flashes 39 times for 15secs then it turns green for 2 secs then goes back to red flashing light, which flashes slowly for 45 secs then the green light comes on flashing rapidly for 10 secs then back to red slow flashes for few mins till eventually stops on solid red, help!!!
The unit your talking about is a micro-display Multi-sync projection TV set. There could be several reasons why this set will not switch on. On could be a bad bulb, there should be an indicator lite on the front panel that will say lamp and should be on all the time or will be flashing. Another reason is there is a problem in the main or standby power supply. I just found out that this set has a three years warranty. If there is no indicator light showing a bad bulb, and this set is less the three years old, Call in an authorized Sanyo repair center to address this problem that you are having. If the set is out of warranty and you have no Micro-Display Tv repair experience, play it safe and call in a repair center to have a look at this set for you, as there are no user replaceable parts inside this set. Good Luck, and let us know what you found was wrong with this TV.
