My 32' LG LCD TV has suddenly lost picture! The sound is all right but the creen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black. I unplugged everything, tried to reset it, no good. PLEASE HELP!
You most likely have a backlight issue with this TV set. Could be the inverter circuits for the backlights. The inverter is the power supply source for the backlights. there could also be a screen driver problem. This would entail changing the entire board. You should call in an authorized LG repair center to check this set out for you. Good Luck and please let us know what you found out about this TV set.
Thank you for your opinion,I wouldn't be able to repair it so I've already called LG service, they'll come and callect it within the next two days. Many thanks for a quick reply!
No problem, and please let us know what they find wrong with the TV set.
I Have the same problem I can not find my reciept to take it back is their anything I can do?
Cheers
I have a LG 42 Inch, once plugged in the TV turns on, but then sound only comes on, no picture just sound, but TV wont turn off thru hitting power button only by unplugging it. the power light flashes like twice again its doesnt turn off only the sound is heard.
Thanks if you can help
I have just experienced this today, don't know what's up... Any solutions?
I am experiencing the same problem with my 42
I have the same problem-sound no picture then no sound. Will not turn on/off right away sometimes not at all
My 42" LG turns on and the screen is small in the top right corner. We must hit exit to expand to full screen every time.
A bit annoying and cannot get it fixed. We'ver reset factory defaults which did not help.
Art
If its not under warranty, pull the back cover and check the capacitors on the power supply. If there are any that are bulging or show signs of fluid leakage, replace them. If that doesn't fix your no picture but sound issue then you have a bigger problem. You can do it yourself pretty cheap and its not that hard. Just make sure you use the proper replacement capacitors. Check out youtube for lcd tv repair and you should find what I am talking about.
my LCD TV (Samsung)has no picture but sound is fine!!!
My 37in lcd lg tv lost sound but have picture. Wont turn off tv from the remote or turn the volume up or down.
I have a 42LG30-UD and I broke the coax connector on the back so I bought a board from some guy. I installed it and now I have sound but no picture. Just a grayish blue screen. The board exactly matches my old one smane part number as well- EAX42499101(7). I just found out that the board I bought came out of a plazma and I have an LCD. Is that why!? Thanks!
i was playing call of duty modern warfare 2 and i killed someone and suddunly my lg lcd tv went all white please help !!!
i was playing modern warfare 2 and i killed someone and my lg lcd tv went white i turned my playstation 3 off still white i unplugged my telly then plugged it in still white plzz helpp
I have a similar problem. I will get a picture for a few minutes and the picture them blinks out. When I hook up to DVD or avi input, iwill get a picture for 30-50 seconds and then it goes black. Sound works fine. I have submitted the question to a paid forum to see if this is anything I may be able to fix. ( I know theory but am not a technician.). It is a LG lcd set- no longer under warranty.
I will post if I learn anything of value.
Just outside of warranty my 42" LG5020 has no picture on the left half of the screen, just a black patch. Right half has no problems. Just showing a complete split down the middle, right half picture, left half nothing???
Any thoughts welcome.
LG lcd tv no picture but normal sound. Its less than a year old tv. Any hint for this trouble? Thanks
Alot of these tv's have bad caps on the smps board start there and look for the obvious swollen caps
My 32 inch Lg LCD tv has sound but the picture seems to be absent. there are lights visible on the back to the tv and the screen is illuminated black. I have been reading up on this issue and it seems others are having the same problem. I purchased the tv over a year and a half ago and cant seem to locate the receipt to hopefully validate the warranty. Can anyone help this situation??
My 55" LG LCD t.v. loses the picture sometimes. Now happening once or twice a day. Picture goes blank (grayish) but sound is fine. When you shut off the t.v. it comes right back on and will play for hours before losing the picture again. Using a Motorola cable DVR box and an Onyko receiver. Doubtful it is caused by the DVR box because the picture is fine when a recorded program is replayed later even when there was picture loss on the t.v. screen during the recording period. TV also loses picture on occasion while replaying a DVR recording but so far not while playing a movie with our blue tooth player.
Recently had the t.v. mounted with remote wiring through the attic for the t.v., receiver and cable box. This never happened before the remote TV mounting though that could be coincidence.
I have same problem with a 48" Samsung. I put a small fan behind it and it is holding picture now.
Hi I have a LG 42 led tv it cums on bit couple of seconds later there is no pic only sound
If I keep the tv of for a couple of days it cums on fine but if I turn it off again it does the same as before.
Plz help the repair guy says its the circuit board and needz 150 to order it and 30 to replace it
Have the same problem but if I leave the tv on for a while say 20 minutes,switch off then turn back on again picture comes on.
Try this http://www.coppelltvrepair.com/p/559/lg-eax50270401-sustain-board-repair...
i have lg tv52lb5df isbacklight come on but no picture and no menu display. what part do i change ?
Can any one help me find out which board i need to replace in my lg 50pc1da .I have picture but only on certain av inputs, i have no working hdmi, ports there is no sound and the cooling fan is constantly running full speed, and the control buttons are working but takes several attempts to get a result ive looked around but not had much luck thanks
My LG flat screen tv has picture only on channels up to channel 526. All other channels have sound but no picture.
