Dual Output HDMI switch
cremona
Got 2 HDTV monitors and want to share them with you new HD Sources or PC.
I got one of these and it works like a KVM switch to switch between 3 HDMI sources between my 2 HDTV.
3x2 HDMI Cross switch http://octavainc.com/HDMI%20switch%20...
The outputs of the HDMI Cross Switch can be independently selected from 3 video inputs. The HDMI Cross switch does not  “split” the input to both displays, which merely shows same video on both display.  The significant advantage of the HDMI Cross Switch is flexibility such as “picture by picture” viewing, independent EDID communication between display and source, and Dual Display switching which maximizes user flexibility.
In addition, the 2 Outputs allows users to switch between 2 displays. Owners of large screen front projectors system and flat panel display can easily select which display they wish to view.  For example, “day to day” HD programming can be switched to the LCD and “weekend viewing” (movies, major sporting events) can be switched to the Projector system thus allowing the user to share video sources and cut down projector bulb “wear and tear”
Why dont you write a review
Why dont you write a review and submit it as an article?
