KP53S25 sony projection tv has no sound/no picture
6 posts / 0 new
dave31
My sony KP53s25 projection tv suddenly went out. There is no sound and no picture. The stand-by light just keeps blinking. Can someone assist me with determining a solution?
How many times does this
How many times does this light blink, as there is a built in diagnostics for these Sony TV set.
dave31
Larry, Thanks for responding
Larry, Thanks for responding. My kp53s25 stand-by indicator light is blinking continously once a second, no pausing. The possible problem indicated by this type of blinking could be no reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective. How would I go about determining which one of these problems I have if any and then fixing it. Is it at all possible that the convergence panel would need to be replaced?
That would all depend on how
That would all depend on how much electronic circuit training you have and if you can use a schematic and know how these TV circuits work.  You will need a mutimeter and a scope to trace the video.  The problem you have is on the M  board or the U board, but a good going over, checking voltage will determi this .
dave31
Larry Dillon said: That
Larry Dillon said: That would all depend on how much electronic circuit training you have and if you can use a schematic and know how these TV circuits work.  You will need a mutimeter and a scope to trace the video.  The problem you have is on the M  board or the U board, but a good going over, checking voltage will determi this .
I located 2 blown fuses (black) on my KP53S25 that are positioned right next to each other on one of the boards. maybe from the M or U board, not sure. Does this info help you pinpoint my no sound or picture with continous (no pause) blinking led indicator light?
kevnor
iwas trying to clean my tv
iwas trying to clean my tv set sony kp53s25 and a wire from the fly bsck jump off i did not know at the time then tried to durn it on after herd a clap sound now only the stan by light keep flashing i replace the horizantal and still no picture no souns can some one help me.
