hook up big screen
6 posts / 0 new
U.L.
hook up big screen
I bought a used vs-45607 the other day and it did not have a manual with it or a remote. I need to know how to hook it up to the satillite receiver. Any help would be much appriciated in this matter.
How to hook this TV set up to
How to hook this TV set up to a satillite receiver will depend on what type of outputs the sat. box has.  If it has an RF or whats called a coax input then simply take a coax cable with the proper f-fitting on the ends and hook up the receiver and tune the tV set to Whatever channel the sat. receiver is set to, or use the s-video output from the receiver to the s-video input of the TV set.   Some or most sat. receivers have a yellow(video), a red( right audio), and a white (left audio) output jack. These are the composite output and can be plugged into the coresponding input jacks on the TV set.  Now remeber the TV set will not know what input your connected to, so you will need to switch the TV set to the correct input, and to do that, you will need the proper remote for this TV set.  You can get the original replacement remote from HERE.  Good luck to you on this hook up and let us know how you made out.
U.L.
Thank you sir for the
Thank you sir for the information. I am going to get started on trying to get it hooked up today. My wife will appreciate it very much. She has trouble seeing due to stroke. Again thank you and I will let you know what happens.
U.L.
No problem and again good
No problem and again good luck to you.  Hope all works out for you.
U.L.
Mr. Dillon, I want to thank
Mr. Dillon, I want to thank you very much on helping me connect this outfit. I found my cord to hook up the tv and YEA it is working. Now to hook up the dvd, vcr, home surrond systems and it will be complete. But I will haave to work on that later. She will not let me do it right now. ha ha
Again, thank you so very much for helping this old man.   U.L.
Thank you so much for your
Thank you so much for your feedback. And your so welcome again for the assistance.
