Need someone to point me in the right direction. TV is dead except for ticking sound. Fuse was not blown. Did a visual inspection and saw nothing burnt but did notice several poor solder connections in the power supply and horizontal areas, which I resoldered. Still ticking. I suspect the problem is in the switching power supply, but not sure. I am an experienced tech so I won't kill myself trying to repair the set. Please help me out.
You really should first download the service manual. You can download one From HERE. next check the schematic voltages on the main regulator with a variac, turn the input voltage to 90 to 95 volts input. If the regulator starts up and keeps shutting down, disconnect the horizontal output transistor connections and try this again. If the voltage comes up and stays, you have a problem in the horizontal output stage, bad flyback transformer or a problem in the sweep power supply. I do not have any notes or repairs on this model. Good luck and let us know what you find.
Please help,
My Sharp 32" TV MODEL#32UF 5/6 Turns on and immediately turns off. The fuse is not blown, I could smell a slight electrical burning from the back of the set.
Any Idea's?
Joe
Love is a telephone which is seldom program-controlled or directly dialed. You cannot get an immediate answer by a mere "hello", let alone go deep into your lover's heart by one call. Usually it had to be relayed by an operator, and you have to be patient in waiting. Destiny is the operator of this phone, who is always irresponsible and fond of laying practical jokes to which she may make you a lifelong victim intentionally or unintentionally.
Love is a telephone which is always busy, When you are ready to die for love, you only find, to your disappointment, the line is already occupied by someone else, and you are greeted only by a busy line. This is an eternal regret handed down from generation to generation and you are only one of those who languish for followers.
[url=http://www.monclerstorejackets.com/]moncler jackets[/url]/[url=http://www.monclerstorejackets.com/]moncler ski[/url]/[url=http://www.monclerstorejackets.com/mj8-shop-for-women.html]moncler ski pants[/url]
