i have a sony videoscape model # KP-46S15 powers on for a few seconds and shuts back down. i have already unplugged , reset ect... i looked on inside of tv and found a fuse blown it has a marking next to it saying F1602 if anyone can help with any info i would highly appreciate it. thanks for your time
you will need to replace the 2 stk392-010 ic's on the large heatsink and change the fuse,check for any leaking caps.
Where are the ic's located and heatsink and fuse also where can u get the parts 404 791-9000
The tv just stays on Stand -by kp-46s15
The exact kit you need with everything you will need is HERE It includes high quality IC's instructions, pico fuses, resistors, and support if you need it.
