hello! I need your help. I have a RCA model # p46151wk rear projection t.v. , it doesn't want to turn on any more. When i press the power button , it just makes this clicking noise. can you help?
He means the eeprom IC, A device that is soldered into place and will need to be reprogrammed once replaced, unless you get a pre programmed device. EEPROM stands for: electronicically eraiseable programable read only memory chip. If you do not have any electronic knowledge or experience , I am afraid this repair is beyond your scope of the quick fix. Please play it safe and refure to a pro to assit you in the repair of this TV set. Good Luck and please let us know how this repair turns out.
before checking the eeprom resolder L14401,and check q14901 the X ray Switch.and r14103 1M.
