sony hs51 projector
shawnsin
sony hs51 projector
i am having trouble with my projector i am getting nothing when powered up the two lights light up yellow, (lens cap and bulb ) the power button lights up ren and not green. the top sony display light lights up for one second and the unit clicks and does nothing. there is no light coming from the lens and no fan noise or nothing. please help............ the bulb only has 250 hours on it.
Sounds like a bad bulb or the
Sounds like a bad bulb or the bulb power supply.  Have you opened the door to service the bulb recently?  Maybe you need to unplug the unit, reseat the door and the bulb assembly, and replug in the projector.  If that does not work, I am afraid the set will need to be seen by a pro.  Good Luck and keep us informed about the progress on this repair.
shawnsin
wow worked like a charm , it
wow worked like a charm , it fixed the problem. i hope it stays that way!!!!! thanks so much for your input!!!!!!!!!!!!!!!!!!!!
