RCA R52WH74 52" Widescreen
AC514
I've read tons of articles where people are having problems with the tubes in this model but I'm only having one very annoying problem. . .
 When I cut on the tv it brings up the choose your language "blue screen" every single time.  Even if you go all the way through that setup process which is lengthy I might add, it still does the same thing the next time you cut the TV on.
Please help
Alan
Are you using a wall switch
Are you using a wall switch or a power strip to turn off the TV set?  If so, thats why as it is not holding the memory in the TV set.  If you are not using a wall switch or a power strip, then the TV set has a bad eeprom IC or bad connections around it.  This is not a job for an end user as this eeprom will need to be reloaded with the technical data thats is used to control the TV set.  Good Luck, and keep us posted on the repair of this TV set.
