Hey there,
I have a Magnavox VCR/DVDR model MWR20V6 that has suddenly started sending an error message; E4 54037380 Can not record to this disc. I have used discs from this same Lot and type (Verbatim DVD-R) numerously and had no problem. This isn't the first machine which this has happened with either. It's almost as if the manufacturers have set a limit on the number of discs that can be recorded on each machine, because the other machine seems to have started messing up at about the same time. Any suggestions?
LTB
