Help On My Old Zenith TV SZ2549P
TheJumpOff
Hello I appriciate anyones help they can give.  I have a Zenith TV model number SZ2549P  It was made in 1984 and its a console TV.  Before you ask "Why is he trying to repair this" let me explain.  This TV was my granfathers.  It hasnt worked since I was 5 years old.  This was state of the art in its day it has something called "Space Phone" basically its a speaker phone inside the TV.  Anyway he lost his fight to cancer back in 2002.  It was always somthing we were going to do together was to fix this but he past prior to us doing it.  He left me this TV thinking it would have been fixed by the both of us, and his old Console Zenith Stereo (Works Great).  I want to fix this TV in his memory and use it in my living room, I know he would be proud.
This is what is happening.  When I plug the unit in and press the power button eaither on the remote or the front panel I hear a click but there is no action its dead other than that click.  Through my granpops teachings I am a do it yourselfer.  So I did alot of research and I found The Main Module board part number 9-214 and replaced it, and I also found part number 9-186-06 Which is the HI Module and replaced it however I still get the same symptom.  The only two boards left are the tuner Module and the Space phone module.  I dont think its these.  When I did replace the Hi Voltage module I noticed that there is a small board with a power supply (SMall) mounted to it this I couldnt really find a part number on but could this be it?  Any help woudl be so greatly appriciated!  Thsi is more than a TV to me.
Nick
Ok I can assist you in
Ok I can assist you in troubleshooting this old gem of a set if you really want to, but we will first need a service manual and I can only find it in a fiche type manual.  Maybe you can find an electronic one.  Also before you spend any more cash in this set, have a tech with a CRT tester come out and check the picture tube, as these CRTs would go bad after being used for a time and then not used for several years, so you could get the set working and then come to find out that the crt is bad or weak.  Good Luck and let us know what you find out.
