HI
I hope someone here can help me. I have a Hitachi LCD Rear Projection TV model # 42V525. It is approximately 18 months old.
For the past couple of weeks, the picture has been getting 'less crisp and bright' .. at first I assumed it was my glasses being dirty, or dust on the screen since I am having some tile work done in my house.
Yesterday, it became so dark as to be impossible to see, until it went completely dark. Sound is fine. Now, it won't even turn on. The lights in the bottom right corner flicker, then the TV shuts itself off.
My problem is this: I live in Mexico and bought the TV locally at Costco. (Yes there are Costcos in Mexico) and when I looked in my Operating Guide for a service center, there don't seem to be any.
So my questions are: Is this a common problem, and if so what do you think it is? We paid around 2,000 USD for this TV so it's not ready to be replaced, however, I am not sure if I should be spending time/money trying to import parts that might be expensive if this is a BIG problem. On the other hand, the manual says something about a 'lamp' needing to be replaced occasionally .. so if this is sort of a regular maintenance thing, then of course I can do it. However, would this explain the other issue of the TV not staying on for more than a minute before turning itself off ?
Please help. We are retired on a fixed income, and this was a large purchase for us, and can't afford to throw away money on a TV that might just become a money pit.
Thanks.
You will have to contact the store where you purchaced the set and see who they use to service the sets. Good luck
Contact Costco. If Costco in Mexico is anything like Costco in the US they offer a free exchange on anything broken. Check into it.
Dear Karen ,just a suggestion, have you checked the light bulb to see if it is burned out.These lcd projection tv's have a light bulb in them just like the portable projectors used in offices and home projection on the ceiling. I would un plug the unit and look for a little door panel marked lamp and it could be 1-4 screws holding it on then unscrew the lamp cage from tv chassis and then look for a dark grey area in the round part near the base of the fillament stem,if it is clear looking all over it then it's probably not the bulb,but it should look well used if the unit is 18 months old and you watch it alot. It is just a suggestion to check.
Sincerely , DC Repairs
Dear Karen ,adding to my previous suggestion, the unit will turn and then go off if the bulb is bad and when a bulb is getting ready to go bad the picture will go darker and darker and you will lose picture sharpness with a bulb going bad(this is a fact.
