tv repair
10 posts / 0 new
cptnelectron
tv repair
samsung tv/vcr combo   no color  everything else seems ok
model # cxd2512  chassis#kh25
any help would be appreciated thanks leroy   aka  electronbandit
Mallik
Our Sony Trinitron TV (Model
Our Sony Trinitron TV (Model KV-27V42) has gone to standby mode since yesterday. The standby/timer light blinks four times and stops. The TV does not start. Could somebody help us resolve this issue? Cry Thanks.
MOtvGuy
Really only a couple things
Really only a couple things that will cause this problem.  The Color oscillator crystal or the Y/C Jungle IC.
cptnelectron
changed jungle ic and color crystal already  results same  was hoping someone might have had this one before  i'll keep looking no schematic  thanks  cptnelectron .
You will need to invest in a
You will need to invest in a schematic as I remember a small capacitor being bad in a set like this for the burst signal from the horizontal circuit.  The only way to find this problem is to trace the burst signal  With an ocilliscope going into the Y/C jungle IC.  Good Luck
cptnelectron
thanks Larry already on
thanks Larry already on search for manual on line  have also checked a few caps around jungle ic  with esr meter  let youknow what happens cptnelectron.
dans_repair_service
According to the tips
According to the tips database, this problem can be caused by a bad vertical IC (IC541).  Try replacing that first.  (TDA8172)
Dan
For no chroma Dan?  Wow thats
For no chroma Dan?  Wow thats a new one for me.
dans_repair_service
I have to say that I was a
I have to say that I was a bit surprised as well.  But at least this time, I'm only the messenger.  This was the Sony tips database BTW.
smax
I have a JVC  32 inch  AV
I have a JVC  32 inch  AV-32F703 chassis  A112 that is about 3 years old.  When I put it on channels 32 and 33 (ESPN & ESPN@) the sound drops off dramtically.  I had the cable guy here and he could not figure out the problem even after we swapped out TV to the same coaxial outlet and it worked fine.  Can someone help me.
smax
