unit had bad pincusion, vert, hor, settings....made all adjustments and saved data & tested unit.....unit went out to customers house and worked for several months,,,lost the adjustment settings again....3rd time in for same issue..
any ideas??????? thanks
I would replace the eeprom. Also I had a problem once with a customer whos RCA TV set was doing that as well. I found out that the customer was trying to do adjustments themselfs through another shop. Good Luck.
thanks i just waned to see if anyone saw that issue
