Mitsubishi Big Screen Model VS-5062
batgrl2u
I have an older Mitsubishi Big Screen Model # VS-5062 that until recently worked great. Everything still works fine, but now the volume is stuck to almost a whisper...Doesn't matter if I use the remote or the control panel on the front of the tv...the bar that relates to the volume that appears on the tv goes up and down, but the actual sound doesn't get louder or softer....I would like to know if there is a way to fix it, or at least manually turn it up to a louder volume.....HELP!!!
ragingigas
Things to consider. Is the
Things to consider. Is the volume pooched on all inputs or just on certain ones (meaning is DVD sound ok vs. Cable). If so then it might be the audio output of the component connected to the tv. From experience I've seen that the majority of audio problem come from cable boxes, specifically Scientific Atlanta.  If this is the case then you want to disable audio control from the box. Example: Volume is set to low on cable box, so audio on tv would have to be blaring for you to hear anything. Let me know if it works.
Goodluck
