TOSHIBA TV TOUCH FOCUS ERROR
EYDER
WE GOT THIS TV ABOUT 3 YEARS AGO. TODAY WE TURNED IT ON AND THE IMAGE IS OUT OF PLACE, EVERYTHING IS DOUBLE, THE COLORS ARE ALSO DISTORTED ???? ANY IDEAS ???
If it looks like the picture
If it looks like the picture is in 3-D then you have the oh so famous convergence IC falure in your TV set.  This repair is not for the unexperience to try and handle out of the blue.  You will need to first get a service manual and have and know how to use a soldering iron.  You will need to remove the two convergence IC's and resolder new ones into the printed circuit board.  You will then need to go into the service mode and do a convergence touch up alighnment.  if you have no solid state printed circuit board experience please call in a pro to assist you in this repair.  good luck, and please let us know if and what it took to repair your TV set.
