I have a RCA CTC169CK5 unit was dead I replaced the eprom and now I have OSD,?But I have no tuning or video in.I do have sound.Replaced tuner with another one still won't tune. Thanks for any help you can give. "Motron"
Was the eeprom a pre programed one or did you use a chipper checker to do this or did you reprogram the eeprom by going into the service numbers? You really should have the proper equipment to replace an eeprom unless you get a preprogramed one as they are only a couple of bucks more BUT you wiull still need to go into the service menu and do some touching up of the alighnments. A service manual will give you all the info you need to adjust the service manu. These settings I am leaving you is just and should be used as a reference and each set is differant. Good Luck and let us know how you made out with this TV set.
SERVICE MENU CHART
PARAMETER#
PARAMETER NAME
VALUERANGE
COMMENTS
00
PASS NO. FOR SERV. ADJUST
MUST SET TO 76
MAY NOT ADVANCE UNTIL VALUE SET
01
HORIZONTAL FREQUENCY
10
SYNC IS KILLED. DON’T GO BELOW 9
02
HORIZONTAL PHASE
08
03
EW DC (WIDTH)
09
27" ONLY
04
EW AMPLITUDE
02
27" ONLY
05
VERTICAL DC
07
06
VERTICAL SIZE
17
07
RED BIAS
29
PRESS MENU BUTTON FOR SETUP LINE
08
GREEN BIAS
35
09
BLUE BIAS
45
10
RED DRIVE
32
11
GREEN DRIVE
28
12
BLUE DRIVE
25
13
SECURITY PASS NO. FOR CHASSIS ALIGN PARAMETERS
MUST SET TO 77
MAY NOT ADVANCE TO HIGHER PARAM. UNTIL VALUE SET.
14
PLL TUNING
41
15
4.5 MHZ TRAP
03
16
VIDEO LEVEL
04
17
FM LEVEL
07
18
B+ TRIM
07
19
RF AGC CHAN 6
27
MAN. TUNE CHAN 6
20
D-PIP CHROMA
60
21
D-PIP TINT
25
22
D-PIP CONTRAST
16
23
D-PIP BRIGHT
18
24
30
25
SECURITY PASS NO. FOR TUN. ALIGN.
78
MAY NOT ADVANCE TO HIGHER PARAM UNTIL VALUE IS SET
SERVICE MENU CHART
PARAMETER#
PARAMETER NAME
VALUE RANGE
COMMENTS
00
MUST SET TO 76
01
10
02
HORIZONTAL PHASE
08
03
EW DC (WIDTH)
09
27" ONLY
04
EW AMPLITUDE
02
27" ONLY
05
VERTICAL DC
07
06
VERTICAL SIZE
17
07
RED BIAS
29
08
GREEN BIAS
35
09
BLUE BIAS
45
10
RED DRIVE
32
11
GREEN DRIVE
28
12
BLUE DRIVE
25
13
MUST SET TO 77
14
PLL TUNING
41
15
4.5 MHZ TRAP
03
16
VIDEO LEVEL
04
17
FM LEVEL
07
18
B+ TRIM
07
19
RF AGC CHAN 6
27
MAN. TUNE CHAN 6
20
D-PIP CHROMA
60
21
D-PIP TINT
25
22
D-PIP CONTRAST
16
23
D-PIP BRIGHT
18
24
30
25
78
