Did some searching of the internet, finally found the info needed to read the hours. This worked for the 84, but I was not able to scroll through the menu.
Here is the procedure for the 94's.
With TV turned on:
1. Press "mute" on the remote - 1/2 mute appears on the screen
2. Press "mute" on the remote again - mute appears on the screen
3. Press "mute" on the remote and hold the mute button -
4. Press the "Menu" button on the TV's front panel. "S" will appear in the upper right corner of the screen.
5. Press the "Menu" button a second time and the "S" will disappear. On the left side of the screen you will see "RCUT"
followed by two numbers.
You are now in the service mode (this is where you can scroll through the options using the up and down channel keys shown above).
6. Press "9" on the remote and you will access the diagnostics page. In the right hand corner is the lamp time in hours.
7. Press "power" button on remote to exit the menu and power off the TV.
CAUTION: Do not use the up and down volume keys on the remote in this menu as it can alter the data and can be dangerous.
With TV turned on:
