goodmans dr319 picture
mixxy
 I have a goodmans dr319 and i set it up with a freeview box.The picture was fine a couple of days ago and now  it seems to be a bit dark.I have tryed reconnecting it , but its the same.Can anbody help.
Have you tryed the freeview
Have you tryed the freeview box on another TV set yet?  Try that to eliminate the TV set or the reciver.  If the TV is dark, Try first to adjust the TV adjustments.  They are most likely on the TV set setup menu.  If that does not work and if you have no TV repair experience, you should take the TV set to your local repair depot for service.  If it turns out to be the Freeview receiver, you will probably need to purchace an new one as most of these are hard to get service info and parts on.  Good Luck, and let us know how you made out with this.
mixxy
Larry Dillon said: Have you
Larry Dillon said: Have you tryed the freeview box on another TV set yet?  Try that to eliminate the TV set or the reciver.  If the TV is dark, Try first to adjust the TV adjustments.  They are most likely on the TV set setup menu.  If that does not work and if you have no TV repair experience, you should take the TV set to your local repair depot for service.  If it turns out to be the Freeview receiver, you will probably need to purchace an new one as most of these are hard to get service info and parts on.  Good Luck, and let us know how you made out with this.
   Hi thank you for your advice.I took out the scart lead from tv and dvd and put them back in and the colour was fine.I switch the tv and dvd off at night and in the morning the picture was dark again.It seems when i take the scart lead out and puts it back in the colour is normal.Is there any way of keeping the colour without having to take out the scart lead everyday.Many thanks mixxy
