If that is a combo unit and you got it from WalMart, the set is made by Funi. This set is a nightmare to work on and get any special parts for. For your problem I have found mostly bad capacitors in the sweep power supply. Not a quicky fix for the untrained person. If you can get a service manual for this set and know how to troubleshoot solid state printed circuit boards, start in the sweep supply and move to the main power supply. Good Luck
I am having the same problem with my Magnavox MWC24T5 model.
Has anyone out there been able to fix this problem? Thank you.
