tv picture
5 posts / 0 new
buckie
tv picture
my sister tv .the picture is not clear the sound is good the back ground  is blery and on the right side of the sreen the picture at close up is blery the lft is not to bad the tv is a panasonic pt-53wx54j.
buckie
are they a way to  make
are they a way to  make adjusts to this tv
Tell me in detail what the
Tell me in detail what the problem is. Is the convergence off?  Yes you can adjust the set but if the convergence all of a suddenly went out onn the convergence then there is a problem with the circuit and adjusting it will not help.  You will need a service manual first.
buckie
that was the problem LARRY
that was the problem LARRY the convergence need adjusted thanks lot.
If the convergence is out by
If the convergence is out by a large margin then you will need to replaced the convergence ICs and then do an alighnment, as when a projection TV set is working good, then all of a suddenly the convergence jumps out of alighnment, it is always the convergence IC's are going bad.  The alighnments are there for minor touchups.
