Hitachi Projection TV Model 65XWX20B
4 posts / 0 new
SC
After switch on,picture stays only for a few seconds and then screen goes blank as if the flyback Tx collapsed.On switching off and switch on,picture comes back but again only for a few seconds.Sound is ok.
Your going to need a service
Your going to need a service manual and check the Hi voltage shutdown circuit and the power supply over voltage circuit.  You did not mention if you still had sound or not.  If you do, I would check the Hi Voltage shutdown circuit for a fault there or in the sweep power supply.  If the sound goes out also, check the main power supply regulation circuit.    If you have no TV repair experience, call in a trained tech to assist you in this repair as this has no quickie fix.  Good luck and let us know how you made out with this repair.
SC
Thanks Dillon, Sound remains
Thanks Dillon, Sound remains on all the time.Only the picture collapses.
Do you know a place on www where I could download the schematics of the High voltage shutdown circuit ? I am in India and the local Hitachi people are unable to help. Thanks once again.....
Regards, SC
No sorry I do not. Jusy keep
No sorry I do not. Jusy keep searching. You should find something. I will continue to look also.
