samsung hdtv convergence help????????
ace electronics
i just put in 2 conv.ics and a fuse....all tested ok...but the  customer  adjusted the  unit after  the ics. went out... the convergence is totaly out ... i got the blue in  ok..and most of the red ,,,but the red on top i  cant get right , it is just so far out any ideas on a good way to  get to a starting point????the middle and bottem are ok ,,the top is no good , i did get the top ok exect for the right side then i tried to get the right side and got it, now the middle and left are distroyed,,,,,,
any ideas on a resetting of the convergence or a good way to adjust it???
also how do you get to the tech service menu???
any help would be great thanks
Did you get a service manual
Did you get a service manual yet for this TV set?.  Doing alighnments on any projection TV is always alot easyer with a service manual.  Doing alighnment without one is dame near impossible unless you spend hours on end trying and retrying.
ace electronics
yea i just got it,,,i was
yea i just got it,,,i was spinning my wheels on it for a while thanks ....
