sony model kp46s15
cptnelectron
sony model kp46s15
haven't heard back lately  on my situation with this set  power light and stndby light don't blink  more than once  which suggest power supply checked for shorts  none  no other model #'s on set   thre is an ic on power board looks like a regulator no shorts around it relay circuit seems ok  swapped out some caps that checked def with esr meter  does anyone have any suggetions power brd no longer available from sony through global elctr supp   toronto thanks cptnelectron.
dans_repair_service
I have found the following
I have found the following possibilities, check the following components and change where appropriate:
Q808 (IRF1640), Q657 (2SC2755), D669 (1SS119), C667 (470mfd 25V), C663 (100mfd 35V)
Dan
