Toshiba recordable dvd player
5 posts / 0 new
tomonastick
Hi
The following problem only occurs with some dvd's.
The player tries to load the dvd, and then after some time it says its "line", and wont play the dvd.
Anyone any ideas?
To me, "line" would imply
To me, "line" would imply that it switched from DVD mode to looking at one of the video inputs on the player. Not sure why it would do this, but that's my first guess. What do you normally do to correct this? Are you able to flip back into DVD mode to play the disc?
tomonastick
 It only seems to do it with some dvds, when it goes "line", it just wont play the dvd.
Are these DVDs that are
Are these DVDs that are recorded, or commercially purchased discs? If recorded, were they recorded on this machine or a different recorder? There's got to be something in common about the discs that cause this, so let's see if we can figure out what it is.
tomonastick
Thanks for that, luckily I
Thanks for that, luckily I found out it was still under warranty, so we have exchanged it.
