New tv & dvd player hookup problems
4 posts / 0 new
Insdude
Have new JVC 27" tv (with tube) and new Sony DVD player.  I'm on Directtv satellite.  Component cables properly hooked up.  Unable to get AV1 or AV2 inputs to produce a picture on the tv.  Directtv remote programmed to operate DVD player but when I switch from Directtv mode to AV1 or AV2 DVD won't play on tv.
So you say the DTV remote
So you say the DTV remote programmed for the DVD but not the TV set?  What happens if you switch to AV1 or AV2 with the JVC renote.  How is the DVD and DTV equipment connected to the TV set.  Where is the output and what output on the DTV receiver is connected to what input of the TV set.  Some features on a universal remote will not work on some brands and models.  Good Luck and let us know what happens.
madamvamp
The DVD player component
The DVD player component video and audio cables are connected directly to their counterpart on the back of the JVC tv.  Been unable to get the tv pix off of either the Directtv, av1, av2 or tv settings on the Direct tv remote.  This includes combining the above with using the tv input button on the Direct tv remote.  Have also played with DVD remote using input buttons 1, 2, and 3 with no success.  As previously mentioned was successful in programming the Direct tv remote to operate the Sony DVD player.  Still no pix from DVD player on TV.
Ok you still have not
Ok you still have not mentioned the TV remote? Like I said maybe the DTV renote does not work the input buttons correctly. Do you have a JVC remote? try using that! If it does not work, there is a problem on the input of the TV set. have an authorized JVC tech take a look at the TV set.
