Your going to need to replace the convergence correction module
Zenith part number:
809-10290
$ 109.20
Then you will need to get the service manual so you can do a convergence alighnment. You can get this part http://www.partstore.com/ModelDetail.aspx?MfgId=83&ModelID=57705&close=1&exact=1. If you do not know how to do this or do not have the TV knowledge to do this alighnment, play it safe and call in a pro to assist you with this repair. Good Luck, and let us know how this repair turns out.
Thanks a million Larry. I will try this asap and let you know how it works out. Once again thanks. Chad
