sony wega kdfe55a20 turns off and on by itself
gvenegas
I have a 55 inch sony rear projection purchased nov 2005, 14 months
new.. the problem is when watching it turns off and on every min. I
have gone through the troubleshooting section and set every thing to
default. timer..etc and no avail, tried unplugging it for a
day., same problem., sony states it needs servicing. not going there
just yet unless i can fix it.. maybe overheating, maybe lamp (no lamp
indicator flashing). somebody help me.. thanks gil
Your problem could be the
Your problem could be the power supply or the light circuit could have a fault.  Does the sound go away at the same time?  Yes I would quess the power supply or the main board is bad.  No?  The bulb circuit most likely is defective.  These TV sets have no user replaceable parts inside of them and should be diagnoised and repaired by a trained technician.  Good Luck, and let us know what was done to repair your TV.
