This indicates that the loading function has not completed correctly. There are a number of padel switches inside the unit used to determine the state of the machine. One or more are in a state to indicate a problem. This usually means that the tray may have a broken tooth underneath and has gotten out of 'time'. This is not a novice repair. If hte try is broken, it will need to be replaced.
Dan
Dan
