broken plasma
4 posts / 0 new
1vanrae
broken plasma
I have a plasma with 4 1 inch stripes going from top to bottom.what do you all think the problem is?and what can I do to fix the problem?
dans_repair_service
This is usually an indication
This is usually an indication that either a portion of the panel is bad or that there is a connection problem for that section.  Please provide teh make and model so that we may help you better.
1vanrae
the plasma with the 1 inch
the plasma with the 1 inch stripe is a sony PFM-42V1
MOtvGuy
You've probably lost a
You've probably lost a verticle display driver IC for that section. Those IC's are normally a part of the panel so a panel replacement will be required to repair the problem.
