RCA CTC197HA ,F27680GY.Help
Silva
Hi Larry it's me again. Again with RCA CTC197AH. You remember i sad that it would worked fine after ajusted the RED BIAS no more bleeding, but it would run fine for 40 minutes and then the horizontal goes out keeping good sound, no pic, if i unplugg from wal and let it sit for some time and try again it come up for same cycle.I just learnd correct me if i'm wrong,>There is an ERROR code,when i enter the service menu #1,#2,#3,are ERROR CODES.and #1 sais 10,and the other two say 0. also i got the code list and it sais 10, this code means FPIP power supply at reset,what you guys think any ggestions
I think your losing your
I think your losing your horizontal drive.  Did you do the coil modification on the base of the horizontal output transistor?  You must take the coil that connects up the base of the horizontal output transistor with the secondary of the horizontal drive transformer.  You must scrap off the enamal and reinsert the coil and resolder.  Simply resoldering the small coil will fix it temporaraly, but it will go out again, so you must do as I said. The coils is L14401.  Good Luck
Silva
Thanks Larry i'll do that and
Thanks Larry i'll do that and post the result.
