help setup xbox 360 on new LCD philips 42pf7621d when using scart every thing works fine but when i setup in HD i get a fantastic picture but no sound can any one help please
Larry Dillon said: Is the scart output set up correctly in the XBox configuation menu ?
i am not using the scart i am wonting it in hd all cables are were they should but no sound i cant see any thing in the menu about the scart if i need to configure it how do i do that thanks for bearing with me
Oh I misunderstood you I thought you said you were using it in the scart mode. Are they the componet cables? Check out this site HERE and see if this helps you. Let us know how you made out.
hi thanks for that but no good its weired the same but theres no sound must be some thing to do with tv
thanks
You did check the setup menu in the audio section of the Xbox, correct?
