Sharp TV switches inputs
4 posts / 0 new
wookie55
I have a 32" Sharp.  While watching, the input switches on its own.  I hit the remote to restore it to input 1 and it will keep switching on its own.  Any ideas?  I have a cable box and TiVo hooked into it, however neither one should affect the input modes.  Thanks
dans_repair_service
Have you installed any new
Have you installed any new flourescent lights recently?  This is a problem that has existed for a long time.  The new replacement bulbs that fit into standard light sockets emit more infrared radiation than regular bulbs in the frequency range of remotes.  Check for this first.
Also when you switch back to
Also when you switch back to the TV when it has switched to video input, quickly remove the batteries out of the remote, as maybe the remote is malfunctioning.Good Luck, and let us know how you made out.uck
wookie55
thanks.  I did recently
thanks.  I did recently replace a standard 18" fluorscent bulb under the counter in the Kitchen.  However, the TV is in the den approximately 25 feet away with walls between.  The bulbs in this room are the newer GE Reveal.  Could they cause this also?  I really appreciate your help. thanks again.
