flashing picture
Chuckez
flashing picture
I have a Sony Trinitron model KV32S36, when the unit is powered on,  the standby light flashes and after several minutes the unit will come on and the picture continually flashes on and off.  Any help is appreciated. Thank you.
dans_repair_service
This is a common problem that
This is a common problem that I have seen with a number of Sony sets.  Check for bad connections on hte PC board around the flyback transformert and the horizontal drive transformer.  Otherwise, this may be an indication that the picture tube is starting to fail.  To confirm this turn up the screen control on the flyback just a bit.  If the picture stays on, this indicates that the picture tube is going.  Turning this up will work for a while but will brighten up the picture a bit as well.  This is only a short term "fix" buying you time to shop for a new set.
Dan
